ArcGIS.Core.Data Namespace / Version Class / Reconcile Method / Reconcile(ReconcileOptions) Method
If ReconcileOptions.TargetVersion is not specified in reconcileOptions, then the target version is the Default version.
Example
    Reconciles this version against a target version specified in reconcileOptions. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function Reconcile( _
       ByVal reconcileOptions As ReconcileOptions _
    ) As ReconcileResult
    Parameters
    reconcileOptions
    Return Value
    An instance of ReconcileResult indicating the results of the operation.
    Exceptions
    ExceptionDescription
    reconcileOptions is null.
    This operation is not supported in client-server mode because the data store supports multi-branch versioning.
    -or-
    Multi-branch versioning does not support a ConflictResolutionType that favors the target version.
    Reconcile cannot be performed in an active edit session.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Illustrate version conflict information from a reconcile operation
      // Must be called within QueuedTask.Run
      void GetVersionConflictsInfoInUpdateDeleteType(
        ServiceConnectionProperties featureServiceConnectionProperties,
        string featureClassName)
        // To illustrate the conflict between versions,
        // the feature is updated in the child version and deleted in the parent version.
        long featureObjectIDForEdit = Int64.MinValue;
        // Get branch versioned service
        using (Geodatabase fsGeodatabase = new Geodatabase(featureServiceConnectionProperties))
        using (VersionManager versionManager = fsGeodatabase.GetVersionManager())
        using (Version defaultVersion = versionManager.GetDefaultVersion())
        using (Geodatabase defaultGeodatabase = defaultVersion.Connect())
        using (FeatureClass defaultFeatureClass = defaultGeodatabase.OpenDataset<FeatureClass>(featureClassName))
        using (FeatureClassDefinition defaultFeatureClassDefinition = defaultFeatureClass.GetDefinition())
          // Create a feature in the default version to edit in a branch
          defaultGeodatabase.ApplyEdits(() =>
            using (RowBuffer rowBuffer = defaultFeatureClass.CreateRowBuffer())
              rowBuffer["NAME"] = "Loblolly Pine";
              rowBuffer["TREEAGE"] = 1;
              rowBuffer[defaultFeatureClassDefinition.GetShapeField()] = new MapPointBuilderEx(new Coordinate2D(1, 1),
                SpatialReferenceBuilder.CreateSpatialReference(4152, 0)).ToGeometry();
              using (Feature feature = defaultFeatureClass.CreateRow(rowBuffer))
                featureObjectIDForEdit = feature.GetObjectID();
          // Add newly created feature in the filter
          QueryFilter queryFilter = new QueryFilter { ObjectIDs = new List<long> { featureObjectIDForEdit } };
          // Create a branch version
          VersionDescription versionDescription = new VersionDescription("UpdateDeleteConflictType",
            "Update-Delete version conflict type", VersionAccessType.Public);
          // Edit the feature in the branch
          using (Version editVersion = versionManager.CreateVersion(versionDescription))
          using (Geodatabase branchGeodatabase = editVersion.Connect())
          using (FeatureClass featureClass = branchGeodatabase.OpenDataset<FeatureClass>(featureClassName))
          using (RowCursor rowCursor = featureClass.Search(queryFilter, false))
            branchGeodatabase.ApplyEdits(() =>
              while (rowCursor.MoveNext())
                using (Row row = rowCursor.Current)
                  row["TREEAGE"] = 100;
                  row["NAME"] = $"{row["Name"]}_EditInBranch";
                  row.Store();
            // Delete the feature from the default version
              defaultFeatureClass.DeleteRows(queryFilter);
            // Reconcile options
            ReconcileOptions reconcileOptions = new ReconcileOptions(defaultVersion)
              ConflictResolutionType = ConflictResolutionType.FavorEditVersion,
              ConflictDetectionType = ConflictDetectionType.ByRow,
              ConflictResolutionMethod = ConflictResolutionMethod.Continue
            // Reconcile with default
            ReconcileResult reconcileResult = editVersion.Reconcile(reconcileOptions);
            // Check for conflicts
            bool hasConflictsReconcileResults = reconcileResult.HasConflicts;
            bool hasConflictsAfterReconcile = editVersion.HasConflicts();
            // Fetch conflicts
            IReadOnlyList<Conflict> conflictsAfterReconcile = editVersion.GetConflicts();
            // Iterate conflicts
            foreach (Conflict conflict in conflictsAfterReconcile)
              // Object ID of row where conflict occurs
              long objectId = conflict.ObjectID;
              ConflictType conflictType = conflict.ConflictType;
              IReadOnlyList<FieldValue> ancestorVersionValues = conflict.AncestorVersionValues;
              object nameAncestor = ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
              object treeAgeAncestor =
                ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
              IReadOnlyList<FieldValue> childVersionValues = conflict.ChildVersionValues;
              object nameChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
              object treeAgeChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
              IReadOnlyList<FieldValue> parentVersionValues = conflict.ParentVersionValues;
              IReadOnlyList<Field> originalFields = defaultFeatureClassDefinition.GetFields();
              string datasetName = conflict.DatasetName;
    Reconciling and Posting a Version with its Parent in separate edit sessions
      void ReconcileAndPost(Geodatabase geodatabase)
        // Get a reference to our version and our parent
        if (geodatabase.IsVersioningSupported())
          using (VersionManager versionManager = geodatabase.GetVersionManager())
          using (Version currentVersion = versionManager.GetCurrentVersion())
          using (Version parentVersion = currentVersion.GetParent())
            // Create a ReconcileOptions object
            ReconcileOptions reconcileOptions = new ReconcileOptions(parentVersion);
            reconcileOptions.ConflictResolutionMethod = ConflictResolutionMethod.Continue; // continue if conflicts are found
            reconcileOptions.ConflictDetectionType = ConflictDetectionType.ByRow; //Default
            reconcileOptions.ConflictResolutionType = ConflictResolutionType.FavorTargetVersion; //or FavorEditVersion
            // Reconcile
            ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions);
            if (!reconcileResult.HasConflicts)
              //No conflicts, perform the post
              PostOptions postOptions = new PostOptions(parentVersion);
              //var postOptions = new PostOptions(); for default version
              postOptions.ServiceSynchronizationType = ServiceSynchronizationType.Synchronous; //Default
              // Post - Deprecated since Pro SDK 3.6 / Enterprise 12.0 . Use Reconcile(reconcileOptions, postOptions) instead.
              // currentVersion.Post(postOptions);
              currentVersion.Reconcile(reconcileOptions, postOptions);
    Requirements
