ArcGIS.Core.Data Namespace / QueryDescription Class / GetObjectIDFields Method
    Gets a comma-separated unique key field(s) that fulfill the role of a table's objectID. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetObjectIDFields() As String
    public string GetObjectIDFields()
    Return Value
    A comma-separated unique key field(s) that fulfill the role of a table's objectID.
    Exceptions
    ExceptionDescription
    A database-related exception has occurred.
    Remarks
    The value returned from this method may be the same as that of GetObjectIDField if IsObjectIDMappedColumnRequired is false. In other words, if a virtual ObjectID column is not required, the values returned from aforementioned methods may be identical.
    Requirements
