ArcGIS.Core.Data.NetworkDiagrams Namespace / DiagramManager Class / GetNetworkDiagrams Method / GetNetworkDiagrams() Method
Example
    Gets the full list of NetworkDiagrams. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function GetNetworkDiagrams() As IReadOnlyList(Of NetworkDiagram)
    public IReadOnlyList<NetworkDiagram> GetNetworkDiagrams()
    Return Value
    A list of NetworkDiagrams.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred. For example, the diagram manager is invalid.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Get Network Diagrams
      static void GetDiagram(UtilityNetwork utilityNetwork, IEnumerable<Guid> globalIDs)
        Envelope extentOfInterest = MapView.Active.Map.GetDefaultExtent();
        using (DiagramManager diagramManager = utilityNetwork.GetDiagramManager())
          // Get all the diagrams
          IReadOnlyList<NetworkDiagram> diagrams = diagramManager.GetNetworkDiagrams();
          // Get a diagram by name
          NetworkDiagram diagram = diagramManager.GetNetworkDiagram(_diagramName);
          // Get diagrams by extent
          diagrams = diagramManager.GetNetworkDiagrams(extentOfInterest);
          // Get diagrams from a set of utility network feature GlobalIDs
          diagrams = diagramManager.GetNetworkDiagrams(globalIDs);
          // Get diagrams from a set of utility network feature GlobalIDs within an extent
          diagrams = diagramManager.GetNetworkDiagrams(extentOfInterest, globalIDs);
    Get a list of Network Diagrams with inconsistent ConsistencyState
      static List<NetworkDiagram> GetInconsistentDiagrams(UtilityNetwork utilityNetwork)
        // Get the DiagramManager from the utility network
          List<NetworkDiagram> networkDiagrams = new List<NetworkDiagram>();
          // Loop through the network diagrams in the diagram manager
          foreach (NetworkDiagram diagram in diagramManager.GetNetworkDiagrams())
            NetworkDiagramInfo diagramInfo = diagram.GetDiagramInfo();
            // If the diagram is not a system diagram and is in an inconsistent state, add it to our list
            if (!diagramInfo.IsSystem &&
                diagram.GetConsistencyState() != NetworkDiagramConsistencyState.DiagramIsConsistent)
              networkDiagrams.Add(diagram);
            else
              diagram.Dispose(); // If we are not returning it we need to Dispose it
          return networkDiagrams;
    Requirements
