ArcGIS.Core.Data Namespace / RangeDomain Class / GetMinValue Method
    GetMinValue Method
    Gets the minimum valid value in the domain. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetMinValue() As Object
    public object GetMinValue()
    Return Value
    The minimum valid value in the domain.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
