ArcGIS.Core.Data Namespace / RangeDomain Class
Properties Methods
    RangeDomain Class Members
    The following tables list the members exposed by RangeDomain.
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public PropertyGets the MergePolicy of the domain. (Inherited from ArcGIS.Core.Data.Domain)
    Public PropertyGets the SplitPolicy of the domain. (Inherited from ArcGIS.Core.Data.Domain)
    Top
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the description of the domain. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Domain)
    Public MethodGets the FieldType of the domain. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Domain)
    Public Method Gets the maximum valid value in the domain. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the minimum valid value in the domain. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the name of the domain. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Domain)
    Top
