ArcGIS.Core.Data Namespace / Relationship Class
Members Example
    Relationship Class
    Represents a pair of related rows (or features) from a geodatabase.
    Object Model
    Relationship ClassRow ClassRow Class
    Syntax
    Public Class Relationship
       Inherits ArcGIS.Core.CoreObjectsBase
       Implements System.IDisposable
    public class Relationship : ArcGIS.Core.CoreObjectsBase, System.IDisposable
    Remarks
    A Relationship represents a relationship between rows and/or features where the tables or feature classes must participate in a RelationshipClass. In this type of relationship, there is no intermediate table to store information about the related rows/features. Relationships are created using RelationshipClass.CreateRelationship and are returned using RelationshipClass.GetRowsRelatedToOriginRows or RelationshipClass.GetRowsRelatedToDestinationRows.
    Example
    Creating a Relationship
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
        using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.OverviewToProject"))
        using (FeatureClass projectsFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjects"))
        using (FeatureClass overviewFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjectsOverview"))
          // This will be PROJNAME. This can be used to get the field index or used directly as the field name.
          string originKeyField = relationshipClass.GetDefinition().GetOriginKeyField();
          EditOperation editOperation = new EditOperation();
          editOperation.Callback(context =>
            // The rows are being added to illustrate adding relationships.
            // If one has existing rows, those can be used to add a relationship.
            using (RowBuffer projectsRowBuffer = projectsFeatureClass.CreateRowBuffer())
            using (RowBuffer overviewRowBuffer = overviewFeatureClass.CreateRowBuffer())
              projectsRowBuffer["TOTCOST"] = 500000;
              overviewRowBuffer[originKeyField] = "LibraryConstruction";
              overviewRowBuffer["PROJECTMAN"] = "John Doe";
              overviewRowBuffer["FUNDSOUR"] = " ";
              using (Row projectsRow = projectsFeatureClass.CreateRow(projectsRowBuffer))
              using (Row overviewRow = overviewFeatureClass.CreateRow(overviewRowBuffer))
                Relationship relationship = relationshipClass.CreateRelationship(overviewRow, projectsRow);
                //To Indicate that the Map has to draw this feature/row and/or the attribute table has to be updated
                context.Invalidate(projectsRow);
                context.Invalidate(overviewRow);
                context.Invalidate(relationshipClass);
          }, projectsFeatureClass, overviewFeatureClass);
          bool editResult = editOperation.Execute();
    Inheritance Hierarchy
    System.Object
          ArcGIS.Core.Data.Relationship
             ArcGIS.Core.Data.AttributedRelationship
    Requirements
