ArcGIS.Core.Data.NetworkDiagrams Namespace / NetworkDiagram Class / GetContent Method / GetContent(Boolean,Boolean,Boolean,Boolean) Method
Indicates whether to return diagram info.
Indicates whether to return geometries of the diagram features.
Indicates whether to return attributes of associated source objects.
Indicates whether to returns aggregations of diagram features.
Example
    Returns diagram information and content as a JSON string. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function GetContent( _
       ByVal addDiagramInfo As Boolean, _
       ByVal addGeometries As Boolean, _
       ByVal addAttributes As Boolean, _
       ByVal addAggregations As Boolean _
    ) As String
    Parameters
    addDiagramInfo
    addGeometries
    addAttributes
    addAggregations
    Return Value
    The JSON string containing the diagram content.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    This JSON string can be used to transfer data into external systems, such as network calculation or analysis software.
    Example
    Get Network Diagram Information as JSON string
      static void GetDiagramContent(UtilityNetwork utilityNetwork)
        using (DiagramManager diagramManager = utilityNetwork.GetDiagramManager())
          // Get a diagram by name
          NetworkDiagram diagram = diagramManager.GetNetworkDiagram(TemplateName);
          string jsonContent = diagram.GetContent(true, true, true, true);
    Requirements
