ArcGIS.Core.Data.NetworkDiagrams Namespace / RelativeMainlineDiagramLayoutParameters Class / LineAttributeName Property
    The name of the network attribute that will be used to identify the lines which compose the straight lines.
    Syntax
    Public Property LineAttributeName As String
    public string LineAttributeName {get; set;}
    Remarks
    This ArcGIS.Core.Data.UtilityNetwork.NetworkAttribute name must exist on the utility network line classes. The values should be the same for all the edges that compose a straight line.
    Requirements
