ArcGIS.Core.Data.NetworkDiagrams Namespace / RelativeMainlineDiagramLayoutParameters Class / MinimalDistance Property
    Minimal distance that must be kept between two adjacent groups of neighbor junctions.
    Syntax
    Public Property MinimalDistance As Double
    public double MinimalDistance {get; set;}
    Remarks
    This minimal distance is also used to group neighbor junctions regarding their projection along the direction axis. Two junctions projected on this axis will belong to the same group when the distance between the two projected points is lower than this distance. The default is 0.
    Requirements
