ArcGIS.Core.Data.NetworkDiagrams Namespace / ReshapeEdgesDiagramLayoutParameters Class
Members
    Represents the Reshape Diagram Edges diagram layout parameters. This layout algorithm processes simple operations on vertices along edges.
    Syntax
    Public NotInheritable Class ReshapeEdgesDiagramLayoutParameters
       Inherits DiagramLayoutParameters
    public sealed class ReshapeEdgesDiagramLayoutParameters : DiagramLayoutParameters
    Remarks
    This layout is used to process simple operations on vertices along edges in network diagrams. It enables you to reduce all vertices or some vertices along diagram edges, square diagram edges with the addition of vertices on edges, and separate diagram edges that overlap.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.NetworkDiagrams.DiagramLayoutParameters
          ArcGIS.Core.Data.NetworkDiagrams.ReshapeEdgesDiagramLayoutParameters
    Requirements
