ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / EllipticArcBuilderEx Constructor / EllipticArcBuilderEx Constructor(Coordinate2D,Double,ArcOrientation,SpatialReference)
The center of the circle.
The radius of the circle.
The orientation of the arc, clockwise or counterclockwise.
(Optional) The spatial reference of the arc. The default value is null.
Example
    Creates a new instance of the EllipticArcBuilderEx class. The new instance will be a circle from a center point and radius.
    Syntax
    Parameters
    centerPt
    radius
    orientation
    spatialReference
    Exceptions
    Remarks
    The start and end point of the circle are equal and are located at the top of the circle.
    Example
    Construct a Circle
      // Construct a circle with center at (-1,-1), radius = 2, and oriented clockwise.
      // Use a builderEx convenience method or use a builderEx constructor.
      Coordinate2D centerPtCoord = new Coordinate2D(-1, -1);
      // Builder convenience methods don't need to run on the MCT.
      EllipticArcSegment circle = EllipticArcBuilderEx.CreateCircle(centerPtCoord, 2, ArcOrientation.ArcClockwise);
      // circle.IsCircular = true
      // circle.IsCounterClockwise = false
      // circle.IsMinor = false
      double startAngle, rotationAngle, centralAngle, semiMajor, semiMinor;
      Coordinate2D actualCenterPt;
      circle.QueryCoords(out actualCenterPt, out startAngle, out centralAngle, out rotationAngle, out semiMajor, out semiMinor);
      // semiMajor = 2.0
      // semiMinor = 2.0
      // startAngle = PI/2
      // centralAngle = -2*PI
      // rotationAngle = 0
      // endAngle = PI/2
      // This EllipticArcBuilderEx constructor doesn't need to run on the MCT.
      EllipticArcBuilderEx builder = new EllipticArcBuilderEx(centerPtCoord, 2, ArcOrientation.ArcClockwise);
      EllipticArcSegment otherCircle = builder.ToSegment();
    Create Circle Text Element
      //Note: Must be on QueuedTask.Run(() => { ...
      //Build geometry
      Coordinate2D center = new Coordinate2D(4.5, 4);
      var eabCir = new EllipticArcBuilderEx(center, 0.5, ArcOrientation.ArcClockwise);
      var cir = eabCir.ToSegment();
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(cir, AttributeFlags.AllAttributes));
      //Set symbology, create and add element to layout
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                      ColorFactory.Instance.GreenRGB, 10, "Arial", "Regular");
      string text = "Circle, circle, circle";
      GraphicElement cirTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.CircleParagraph, poly, sym, text, "New Circle Text", false);
    Create Ellipse Text Element
      //Build geometry
      Coordinate2D center = new Coordinate2D(4.5, 2.75);
      var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45, ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
                            ColorFactory.Instance.BlueRGB, 10, "Arial", "Regular");
      string text = "Ellipse, ellipse, ellipse";
      GraphicElement ge = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.PolygonParagraph, poly, sym, text, "New Ellipse Text", false);
    Create Predefined Shape Graphic Element 3
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 2.75);
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
                            ColorFactory.Instance.GreenRGB, 2.0, SimpleLineStyle.Dot);
      CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                       ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical, outline);
      var ge = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
        layout, PredefinedShape.Ellipse, poly.Extent.Center, 0, 0, ellipseSym,
        "New Ellipse2", false, new ElementInfo() { Anchor = Anchor.TopRightCorner });
    Requirements
