ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / EllipticArcBuilderEx Constructor / EllipticArcBuilderEx Constructor(Segment,Boolean,ArcOrientation,Double,Double,SpatialReference)
The segment to which the constructed arc will be tangent at its start or end point.
The boolean indicating if the arc should be constructed at the start or end of the tangent segment.
The value indicating if the arc is oriented clockwise or counterclockwise.
The radius of the arc. Must not be NaN or equal to zero. If the radius is < 0, then the absolute value is used.
The length of the arc. Must not be NaN or equal to zero. If the arcLength is < 0, then the absolute value is used.
(Optional) The spatial reference of the arc. The default value is null.
    Creates a new instance of the EllipticArcBuilderEx class. The new instance will be a circular arc.
    Syntax
    Parameters
    tangentSegment
    atStart
    orientation
    radius
    arcLength
    spatialReference
    Exceptions
    ExceptionDescription
    The tangent segment is null.
    The radius or arc length is equal to zero.
    The radius or arc length is NaN.
    Remarks
    Elliptic Arc Constructor
    Requirements
