ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / CreateCircularArc Method / CreateCircularArc(Double,Double,Coordinate2D,Double,SpatialReference) Method
The angle, measured from a horizontal line through the circular arc's center point, that defines where the arc starts.
The angle which describes the span of the circular arc.
The center point of the embedded circle.
The distance from the center of the embedded circle to the perimeter.
(Optional) The spatial reference of the arc. The default value is null.
Example
    Convenience method to create a new instance of the EllipticArcSegment class. The segment will be a circular arc.
    Syntax
    Public Overloads Shared Function CreateCircularArc( _
       ByVal startAngle As Double, _
       ByVal centralAngle As Double, _
       ByVal centerPt As Coordinate2D, _
       ByVal radius As Double, _
       Optional ByVal spatialReference As SpatialReference _
    ) As EllipticArcSegment
    Parameters
    startAngle
    centralAngle
    centerPt
    radius
    spatialReference
    Return Value
    Exceptions
    Example
    Construct a Circular Arc - using a center point, angle and radius
      // Construct a circular arc with center point at (0, 0), from angle = 0,
      // central angle = pi/2, radius = 1.
      // Use a builderEx convenience method or use a builderEx constructor.
      SpatialReference sr4326 = SpatialReferences.WGS84;
      Coordinate2D centerPt = new Coordinate2D(0, 0);
      double fromAngle = 0;
      double centralAngle = Math.PI / 2;
      double radius = 1;
      // BuilderEx convenience methods don't need to run on the MCT.
      EllipticArcSegment circularArcBuilder = EllipticArcBuilderEx.CreateCircularArc(fromAngle, centralAngle, centerPt, radius, sr4326);
      // BuilderEx constructors don't need to run on the MCT.
      EllipticArcBuilderEx ellipticArcBuilderEx = new EllipticArcBuilderEx(fromAngle, centralAngle, centerPt, radius, sr4326);
      ellipticArcSegment = ellipticArcBuilderEx.ToSegment();
    Requirements
