ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / CreateCircularArc Method
    Overload List
    OverloadDescription
    Convenience method to create a new instance of the EllipticArcSegment class. The segment will be a circular arc built from three points.
    Convenience method to create a new instance of the EllipticArcSegment class. The segment will be a circular arc built from end points and the center point.
    Convenience method to create a new instance of the EllipticArcSegment class. The segment will be a circular arc.
    Convenience method to create a new instance of the EllipticArcSegment class. The segment will be a circular arc of the given radius and tangent to two segments.
    Builds a new instance of the EllipticArcSegment class. The new instance will be a circular arc.
    Creates a new instance of the EllipticArcSegment class. The new instance will be a circular arc.
    Requirements
