ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / CreateEllipse Method
The center point of the ellipse.
The angle in radians by which the ellipse is rotated from the X-axis. A positive value corresponds to counterclockwise rotation.
The length of the semi-major axis.
The ratio of the length of the semi-minor axis to the length of the semi-major axis. The absolute value must be <= 1.
The ellipse orientation, clockwise or counterclockwise.
(Optional) The spatial reference of the ellipse. The default value is null.
Example
    Convenience method to create a new instance of the EllipticArcSegment class. The segment will be an ellipse.
    Syntax
    Parameters
    centerPt
    rotationAngle
    semiMajorAxis
    minorMajorRatio
    orientation
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    rotationAngle, semiMajorAxis or minorMajorRatio is NaN.
    An elliptic arc construction operation was given invalid axes. The absolute value of minorMajorRatio is > 1.
    centerPt is empty.
    Remarks
    If minorMajorRatio is equal to one, then a circular arc will be created and the rotation angle will be equal to zero.
    Example
    Construct an Ellipse
      // Construct an ellipse centered at (1, 2) with rotationAngle = -pi/6,
      // semiMajorAxis = 5, minorMajorRatio = 0.2, oriented clockwise.
      // Use a builderEx convenience method or use a builderEx constructor.
      Coordinate2D centerPt = new Coordinate2D(1, 2);
      // BuilderEx convenience methods don't need to run on the MCT.
      EllipticArcSegment ellipse = EllipticArcBuilderEx.CreateEllipse(centerPt, -1 * Math.PI / 6, 5, 0.2, ArcOrientation.ArcClockwise);
      // This EllipticArcBuilderEx constructor doesn't need to run on the MCT.
      EllipticArcBuilderEx builder = new EllipticArcBuilderEx(centerPt, -1 * Math.PI / 6, 5, 0.2, ArcOrientation.ArcClockwise);
      EllipticArcSegment anotherEllipse = builder.ToSegment();
    Requirements
