ArcGIS.Core.Geometry Namespace / MultipartBuilderEx Class / ReplaceSegment Method
Zero-based index. Specify 0 to replace a segment from the first part. Specify PartCount - 1 or -1 to replace a segment from the last part.
Zero-based index. Specify 0 to replace the first segment. Specify GetSegmentCount - 1 or -1 to replace the last segment.
The new segment.
Example
    Replace the segment at the specified index from the part specified by partIndex.
    Note: Values of partIndex = -1, segmentIndex = -1 replaces the last segment from the last part of the multipart.
    Syntax
    public void ReplaceSegment(
       int partIndex,
       int segmentIndex,
       Segment segment
    Public Sub ReplaceSegment( _
       ByVal partIndex As Integer, _
       ByVal segmentIndex As Integer, _
       ByVal segment As Segment _
    Parameters
    partIndex
    segmentIndex
    segment
    The new segment.
    Exceptions
    ExceptionDescription
    The input segment is null.
    The input part index is > PartCount - 1 or the input segment index is > GetSegmentCount - 1.
    Example
    Create 3D Polyline and set Z-values while preserving curve segments
      PolylineBuilderEx polylineBuilder = new PolylineBuilderEx(polyline);
      polylineBuilder.HasZ = true;
      // The HasZ property is set to true for all the points in
      // polyline3D when you call ToGeometry().
      Polyline polyline3D = polylineBuilder.ToGeometry();
      // For this example, create Z-values.
      // You may want to pass them in as a parameter.
      int numPoints = polyline3D.PointCount;
      double[] zValues = new double[numPoints];
      for (int i = 0; i < numPoints; i++)
        zValues[i] = i % 2 == 0 ? 2 : 1;
      // We need to know at which point index each part starts
      int partPointIndex = 0;
      int numParts = polyline3D.PartCount;
      for (int i = 0; i < numParts; i++)
        var part = polyline3D.Parts[i];
        int numSegmentsInPolyline3D = part.Count;
        for (int j = 0; j < numSegmentsInPolyline3D; j++)
          Segment segment = part[j];
          MapPointBuilderEx pointBuilder = new MapPointBuilderEx(segment.StartPoint);
          pointBuilder.Z = zValues[partPointIndex++];
          MapPoint startPoint = pointBuilder.ToGeometry();
          // Make sure that the end point of this segment is the same as the start point of the next segment
          pointBuilder = new MapPointBuilderEx(segment.EndPoint);
          pointBuilder.Z = zValues[partPointIndex];
          MapPoint endPoint = pointBuilder.ToGeometry();
          SegmentType segmentType = segment.SegmentType;
          SegmentBuilderEx segmentBuilder = null;
          switch (segmentType)
            case SegmentType.Line:
              segmentBuilder = new LineBuilderEx((LineSegment)segment);
              break;
            case SegmentType.Bezier:
              segmentBuilder = new CubicBezierBuilderEx((CubicBezierSegment)segment);
              break;
            case SegmentType.EllipticArc:
              segmentBuilder = new EllipticArcBuilderEx((EllipticArcSegment)segment);
              break;
          // Only change the start and end point which now have Z-values set.
          // This will preserve the curve if the segment is an EllipticArcSegment or CubicBezierSegment.
          segmentBuilder.StartPoint = startPoint;
          segmentBuilder.EndPoint = endPoint;
          segment = segmentBuilder.ToSegment();
          polylineBuilder.ReplaceSegment(i, j, segment);
        // Move point index for the next part
        partPointIndex++;
    Requirements
