ArcGIS.Core.Geometry Namespace / MultipartBuilderEx Class / ReverseOrientation Method
Example
    ReverseOrientation Method (MultipartBuilderEx)
    Changes the direction of the parts without changing the spatial position of the parts. The start point and end point of each segment in each part are interchanged.
    Syntax
    public void ReverseOrientation()
    Public Sub ReverseOrientation()
    Remarks
    Caution should be taken when using ReverseOrientation on polygons. Since ReverseOrientation changes the direction of each part within the polygon, all exterior rings become interior rings and vice versa.
    GeometryEngine Reverse Orientation
    Example
    Reverse the order of points in a Polyline
      var polylineBuilder = new PolylineBuilderEx(polyline);
      polylineBuilder.ReverseOrientation();
      Polyline reversedPolyline = polylineBuilder.ToGeometry();
    Requirements
