ArcGIS.Core.Geometry Namespace / MultipatchBuilderEx Class / FromBinaryXml Method
Binary XML string representation of Multipatch.
Example
    Creates a new instance of a Multipatch class from a binary XML string representation.
    Syntax
    public static Multipatch FromBinaryXml(
       string xmlString
    Public Shared Function FromBinaryXml( _
       ByVal xmlString As String _
    ) As Multipatch
    Parameters
    xmlString
    Return Value
    Exceptions
    ExceptionDescription
    The xmlString is empty or null.
    The XML string is invalid or does not represent a multipatch string.
    Example
    Construct Multipatch
      // export to binary xml
      string binaryXml = multipatch.ToBinaryXml();
      // xml export / import
      string xml = multipatch.ToXml();
      // esriShape export/import
      byte[] buffer = multipatch.ToEsriShape();
      // import from binaryXML - methods need to run on the MCT
      await QueuedTask.Run(() =>
        Multipatch binaryMultipatch = MultipatchBuilderEx.FromBinaryXml(binaryXml);
        Multipatch xmlMultipatch = MultipatchBuilderEx.FromXml(xml);
        Multipatch esriPatch = MultipatchBuilderEx.FromEsriShape(buffer);
      // or use GeometryEngine
      Multipatch patchImport = GeometryEngine.Instance.ImportFromEsriShape(EsriShapeImportFlags.EsriShapeImportDefaults, buffer, multipatch.SpatialReference) as Multipatch;
    Requirements
