public static Multipatch FromXml( string xmlString )
Public Shared Function FromXml( _ ByVal xmlString As String _ ) As Multipatch
Parameters
- xmlString
- XML string representation of Multipatch.
Return Value
A Multipatch.
| Exception | Description |
| System.ArgumentNullException | The xmlString is empty or null. |
| ArcGIS.Core.Geometry.Exceptions.GeometryObjectException | The XML string is invalid or does not represent a multipatch string. |
// export to binary xml
string binaryXml = multipatch.ToBinaryXml();
// xml export / import
string xml = multipatch.ToXml();
// esriShape export/import
byte[] buffer = multipatch.ToEsriShape();
// import from binaryXML - methods need to run on the MCT
await QueuedTask.Run(() =>
Multipatch binaryMultipatch = MultipatchBuilderEx.FromBinaryXml(binaryXml);
Multipatch xmlMultipatch = MultipatchBuilderEx.FromXml(xml);
Multipatch esriPatch = MultipatchBuilderEx.FromEsriShape(buffer);
// or use GeometryEngine
Multipatch patchImport = GeometryEngine.Instance.ImportFromEsriShape(EsriShapeImportFlags.EsriShapeImportDefaults, buffer, multipatch.SpatialReference) as Multipatch;
