ArcGIS.Core.Geometry Namespace / MultipointBuilderEx Class / AddPoints Method / AddPoints(IEnumerable<MapPoint>) Method
The MapPoint enumeration to add. It cannot be null.
    Add an enumeration of points to the list of points.
    Syntax
    Public Overloads Sub AddPoints( _
       ByVal points As IEnumerable(Of MapPoint) _
    public void AddPoints(
       IEnumerable<MapPoint> points
    Parameters
    points
    Exceptions
    ExceptionDescription
    The input point enumeration is null.
    Remarks
    The XY-values of the points are added to the end of the Coordinate2Ds list. If the point property HasZ is true, and this builder property HasZ is true, then the Z-value of the point is added to the end of the Zs list. The same is true for Ms and IDs. If the point is missing any of the attributes (Z, M, or ID) that are present in this builder, a default value is used. The default value for Z is zero, M is NaN, and ID is zero. If a point has an attribute that is missing in the builder, the attribute is ignored.
    Requirements
