ArcGIS.Core.Geometry Namespace / MultipointBuilderEx Class / SetPoint Method / SetPoint(Int32,Double,Double) Method
The index of the point to modify. Must be in the range [0, Coordinate2Ds.Count - 1] inclusive.
The X-value to set.
The Y-value to set.
    Update the point at the specified index with the specified coordinates.
    Syntax
    Public Overloads Sub SetPoint( _
       ByVal index As Integer, _
       ByVal x As Double, _
       ByVal y As Double _
    public void SetPoint(
       int index,
       double x,
       double y
    Parameters
    index
    x
    The X-value to set.
    y
    The Y-value to set.
    Exceptions
    ExceptionDescription
    The point index is < 0 or the point index is >= Coordinate2Ds.Count.
    Requirements
