Return Value
The name of the origin (primary) key field.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.OverviewToProject"))
using (FeatureClass projectsFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjects"))
using (FeatureClass overviewFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjectsOverview"))
// This will be PROJNAME. This can be used to get the field index or used directly as the field name.
string originKeyField = relationshipClass.GetDefinition().GetOriginKeyField();
EditOperation editOperation = new EditOperation();
editOperation.Callback(context =>
// The rows are being added to illustrate adding relationships.
// If one has existing rows, those can be used to add a relationship.
using (RowBuffer projectsRowBuffer = projectsFeatureClass.CreateRowBuffer())
using (RowBuffer overviewRowBuffer = overviewFeatureClass.CreateRowBuffer())
projectsRowBuffer["TOTCOST"] = 500000;
overviewRowBuffer[originKeyField] = "LibraryConstruction";
overviewRowBuffer["PROJECTMAN"] = "John Doe";
overviewRowBuffer["FUNDSOUR"] = " ";
using (Row projectsRow = projectsFeatureClass.CreateRow(projectsRowBuffer))
using (Row overviewRow = overviewFeatureClass.CreateRow(overviewRowBuffer))
Relationship relationship = relationshipClass.CreateRelationship(overviewRow, projectsRow);
//To Indicate that the Map has to draw this feature/row and/or the attribute table has to be updated
context.Invalidate(projectsRow);
context.Invalidate(overviewRow);
context.Invalidate(relationshipClass);
}, projectsFeatureClass, overviewFeatureClass);
bool editResult = editOperation.Execute();
