ArcGIS.Core.Data Namespace / RelationshipClassDefinition Class
Properties Methods
    RelationshipClassDefinition Class Members
    The following tables list the members exposed by RelationshipClassDefinition.
    Public Properties
     NameDescription
    Public PropertyOverridden.  Gets the dataset type.
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Top
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the alias name of the definition. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the label that displays when navigating from the destination to the origin.
    Public Method Gets the valid cardinality of the relationship. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the name of the destination class. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the label that displays when navigating from the origin to the destination.
    Public Method Gets the message notification direction.
    Public Method Gets the name of the definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Definition)
    Public Method Gets the name of the origin class. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the name of the origin foreign key field. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the name of the origin (primary) key field. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the list of relationship rules in the relationship class.
    Public MethodGets the split policy of the RelationshipClass. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a value which indicates if the relationship is used to enable attachment support for a table. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a value indicating whether the lifetime of the destination rows are dependent on the lifetime of the origin rows. This method must be called on the MCT. Use QueuedTask.Run.
    Top
