ArcGIS.Core.Data Namespace / RelationshipClassDefinition Class / IsAttachmentRelationship Method
    Gets a value which indicates if the relationship is used to enable attachment support for a table. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function IsAttachmentRelationship() As Boolean
    public bool IsAttachmentRelationship()
    Return Value
    true if the relationship is used to enable attachment support for a table; otherwise, false.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    If IsAtttachmentRelationship is true the methods on origin Table with Attachment should be used to work with this relationshipclass.
    Requirements
