ArcGIS.Core.Geometry Namespace / SpatialReference Class / GetPCSHorizon Method
A boolean indicating whether the horizon is inclusive or exclusive.
    Gets the horizon of the projected coordinate system.
    Syntax
    Public Function GetPCSHorizon( _
       ByRef isInclusive As Boolean _
    ) As Polygon
    public Polygon GetPCSHorizon(
       out bool isInclusive
    Parameters
    isInclusive
    Return Value
    The horizon of the projected coordinate system.
    Exceptions
    ExceptionDescription
    This instance is not a projected coordinate system.
    Remarks
    The horizon is the valid area of use based on the coordinates of the projected coordinate system. The horizon's coordinates will use the same linear unit of measure as the source projected coordinate system. The horizon can be inclusive or exclusive. Some projection horizons will include all but a small area. In those cases, it's easier to construct an exclusive horizon. The horizon can also be single or multipart polygon.
    Requirements
