string json = "{\"curvePaths\":[[[-13046586.8335,4036570.6796000004]," +
"{\"c\":[[-13046645.107099999,4037152.5873000026]," +
"[-13046132.776277589,4036932.1325614937]]}]],\"spatialReference\":{\"wkid\":3857}}";
polyline = PolylineBuilderEx.FromJson(json);
EllipticArcSegment arc = polyline.Parts[0][0] as EllipticArcSegment;
// No extension, distanceAlongCurve = 0.5
// use the polyline
Polyline poly_normal = GeometryEngine.Instance.QueryNormal(polyline, SegmentExtensionType.NoExtension, 0.5, AsRatioOrLength.AsRatio, 1000);
// or a segment
LineSegment seg_normal = GeometryEngine.Instance.QueryNormal(arc, SegmentExtensionType.NoExtension, 0.5, AsRatioOrLength.AsRatio, 1000);
// TangentAtFrom, distanceAlongCurve = -1.2
poly_normal = GeometryEngine.Instance.QueryNormal(polyline, SegmentExtensionType.ExtendTangentAtFrom, -1.2, AsRatioOrLength.AsRatio, 1000);
seg_normal = GeometryEngine.Instance.QueryNormal(arc, SegmentExtensionType.ExtendTangentAtFrom, -1.2, AsRatioOrLength.AsRatio, 1000);
// TangentAtTo (ignored because distanceAlongCurve < 0), distanceAlongCurve = -1.2
poly_normal = GeometryEngine.Instance.QueryNormal(polyline, SegmentExtensionType.ExtendTangentAtTo, -1.2, AsRatioOrLength.AsRatio, 1000);
seg_normal = GeometryEngine.Instance.QueryNormal(arc, SegmentExtensionType.ExtendTangentAtTo, -1.2, AsRatioOrLength.AsRatio, 1000);
// TangentAtTo, distanceAlongCurve = 1.2
poly_normal = GeometryEngine.Instance.QueryNormal(polyline, SegmentExtensionType.ExtendTangentAtTo, 1.2, AsRatioOrLength.AsRatio, 1000);
seg_normal = GeometryEngine.Instance.QueryNormal(arc, SegmentExtensionType.ExtendTangentAtTo, 1.2, AsRatioOrLength.AsRatio, 1000);
// TangentAtFrom (ignored because distanceAlongCurve > 0), distanceAlongCurve = 1.2
poly_normal = GeometryEngine.Instance.QueryNormal(polyline, SegmentExtensionType.ExtendTangentAtFrom, 1.2, AsRatioOrLength.AsRatio, 1000);
seg_normal = GeometryEngine.Instance.QueryNormal(arc, SegmentExtensionType.ExtendTangentAtFrom, 1.2, AsRatioOrLength.AsRatio, 1000);
// EmbeddedAtTo, distanceAlongCurve = 1.2
poly_normal = GeometryEngine.Instance.QueryNormal(polyline, SegmentExtensionType.ExtendEmbeddedAtTo, 1.2, AsRatioOrLength.AsRatio, 1000);
seg_normal = GeometryEngine.Instance.QueryNormal(arc, SegmentExtensionType.ExtendEmbeddedAtTo, 1.2, AsRatioOrLength.AsRatio, 1000);
// EmbeddedAtFrom, distanceAlongCurve = -0.2
poly_normal = GeometryEngine.Instance.QueryNormal(polyline, SegmentExtensionType.ExtendEmbeddedAtFrom, -0.2, AsRatioOrLength.AsRatio, 1000);
seg_normal = GeometryEngine.Instance.QueryNormal(arc, SegmentExtensionType.ExtendEmbeddedAtFrom, -0.2, AsRatioOrLength.AsRatio, 1000);
