ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / QueryPointAndDistance3D Method / QueryPointAndDistance3D(Segment,SegmentExtensionType,MapPoint,AsRatioOrLength,Double,Double) Method
The segment on which to find the closest point. The segment may be extended.
Describes if, how and where to extend segments.
The input point.
Determines whether the distanceAlongCurve is returned as a ratio of the curve length or as length from the start point.
Describes the distance from the start point of the segment to the input point, either as a ratio or length. If the input point is not on the segment, then the nearest location on the segment from the point is used.
Describes how far the point is from the curve.
    Finds the point on the curve closest to inPoint, then copies that point to outPoint. The operation is performed in 3D space. Also calculates related items.
    Syntax
    Parameters
    segment
    extensionType
    inPoint
    The input point.
    asRatioOrLength
    distanceAlongCurve
    distanceFromCurve
    Return Value
    MapPoint representing the closest point on the curve.
    Exceptions
    ExceptionDescription
    Either segment or inPoint or both are null or empty.
    segment is not Z-Aware.
    Cannot do 3D operations on curve segments.
    Spatial reference of segmentis an image coordinate system.
    Requirements
