ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / QueryTangent Method / QueryTangent(Multipart,SegmentExtensionType,Double,AsRatioOrLength,Double) Method
The multipart to which the tangent line is constructed.
Specifies the extension method that determines the direction and position of the tangent line.
Specifies the distance along the segment from which the tangent line is constructed.
Determines whether the distanceAlongCurve is returned as a ratio of the segment length or as length from the start point.
Specifies the length of the returned tangent line.
Example
    Constructs a line tangent to a multipart from a point at a specified distance along the curve.
    Syntax
    Parameters
    multipart
    extensionType
    distanceAlongCurve
    asRatioOrLength
    tangentLength
    Return Value
    Polyline representing the tangent line.
    Exceptions
    ExceptionDescription
    multipartis null or empty.
    Spatial reference of multipartis an image coordinate system.
    Remarks
    The returned tangent line is in the same direction of the input multipart. The distanceAlongCurve parameter can be negative, and it can be larger than the length of the multipart. The extensionType parameter is ignored if distanceAlongCurve is greater than zero and less than the length of the multipart. For example, shown below in blue is a polyline that contains an elliptic arc segment with its start point in green and end point in red. The orange tangent line is constructed halfway along the curve and the extensionType parameter is ignored.
    QueryTangent_NoExtensionHalfway
    If distanceAlongCurve is less than zero, then the tangent line is embedded in an extension from the start point of the multipart. In the following example, distanceAlongCurve = -1.2, asRatioOrLength = AsRatioOrLength.AsRatio, and extensiontype = SegmentExtensionType.ExtendTangentAtFrom. The extended tangent segment is the gray dashed line and is 1.2 * length of the input polyline. The constructed tangent is in orange.
    QueryTangent_TangentAtFromNegative
    If distanceAlongCurve is greater than the length of the input multipart, then the tangent line is embedded in an extension from the end point of the multipart. In the following example, distanceAlongCurve = 1.2, asRatioOrLength = AsRatioOrLength.AsRatio, and extensionType = SegmentExtensionType.ExtendTangentAtTo. Note that if asRatioOrLength = AsRatioOrLength.AsRatio, then the length of the input multipart is 1. The extended tangent segment is the gray dashed line and is 0.2 * length of the input polyline. The constructed tangent is in orange.
    QueryTangent_TangentAtToPositive
    SegmentExtensionType.ExtendEmbeddedAtTo, SegmentExtensionType.ExtendEmbeddedAtFrom, and SegmentExtensionType.ExtendEmbedded when applied to an elliptic arc segment refer to the embedded ellipse or circle. Shown below in blue is a polyline with an elliptic arc segment that is circular along with its embedded circle in gray.
    QueryTangent_ArcWithEmbeddedCircle
    Here is an example where distanceAlongCurve = 1.2, asRatioOrLength = AsRatioOrLength.AsRatio, and extensionType = SegmentExtensionType.ExtendEmbeddedAtTo.
    QueryTangent_EmbeddedAtToPositive
    If the input segment to be extended is not an elliptic arc segment, then SegmentExtensionType.ExtendEmbeddedAtTo, SegmentExtensionType.ExtendEmbeddedAtFrom, and SegmentExtensionType.ExtendEmbedded are equivalent to SegmentExtensionType.ExtendTangentAtTo, SegmentExtensionType.ExtendTangentAtFrom, and SegmentExtensionType.ExtendTangent respectively. There are cases when the tangent cannot be extended as specified by the extensionType parameter. For example, if the distanceAlongCurve is negative and extensionType = SegmentExtensionType.ExtendTangentAtTo. In this case, the tangent line is constructed at the start point of the input multipart. Similarly, if the distanceAlongCurve is greater than the length of the input segment and extensionType = SegmentExtensionType.ExtendTangentAtFrom, then the tangent line is constructed at the end point of the input multipart.
    Example
    QueryTangent
      LineSegment line = LineBuilderEx.CreateLineSegment(new Coordinate2D(0, 0), new Coordinate2D(1, 0));
      // No extension, distanceAlongCurve = 0.5
      LineSegment tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.NoExtension, 0.5, AsRatioOrLength.AsRatio, 1);
      // tangent.StartCoordinate = (0.5, 0.0)
      // tangent.EndCoordinate = (1.5, 0.0)
      tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.NoExtension, 1.5, AsRatioOrLength.AsLength, 1);
      // tangent.StartCoordinate = (1.0, 0.0)
      // tangent.EndCoordinate = (2.0, 0.0)
      tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.ExtendTangentAtTo, 1.5, AsRatioOrLength.AsLength, 1);
      // tangent.StartCoordinate = (1.5, 0.0)
      // tangent.EndCoordinate = (2.5, 0.0)
      tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.ExtendTangentAtFrom, -1.5, AsRatioOrLength.AsLength, 1);
      // tangent.StartCoordinate = (-1.5, 0.0)
      // tangent.EndCoordinate = (-0.5, 0.0)
      tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.ExtendTangentAtFrom, -0.5, AsRatioOrLength.AsRatio, 1);
      // tangent.StartCoordinate = (-0.5, 0.0)
      // tangent.EndCoordinate = (0.5, 0.0)
    Requirements
