ArcGIS.Desktop.Editing Namespace / ElevationCapturing Class / ElevationSurfaceLayer Property
    Gets or sets the elevation surface layer to be used with ElevationCaptureMode.Surface mode elevation capturing.
    Syntax
    Public Shared Property ElevationSurfaceLayer As ElevationSurfaceLayer
    public static ElevationSurfaceLayer ElevationSurfaceLayer {get; set;}
    Exceptions
    ExceptionDescription
    when attempting to set an elevation surface layer that is not within the currently edited map
    Remarks
    Setting a null layer is valid, indicating the default Ground elevation surface layer should be chosen.
    Requirements
