// Transforms features from a source layer to a target layer using a specified transformation method. var transformMapView = MapView.Active; if (transformMapView == null) return; await QueuedTask.Run(() => { //Transform features using EditOperation.Transform overloads var transformFeatures = new EditOperation() { Name = "Transform Features" }; //Transform a selected set of features ////Perform an affine transformation //transformFeatures.TransformAffine(featureLayer, linkLayer); var affine_transform = new TransformByLinkLayer() { LinkLayer = linkLayer, TransformType = TransformMethodType.Affine //TransformMethodType.Similarity }; //Transform a selected set of features transformFeatures.Transform(transformMapView.GetFeatures(polygon), affine_transform); //Perform an affine transformation transformFeatures.Transform(featureLayer, affine_transform); //Execute to execute the operation //Must be called within QueuedTask.Run if (!transformFeatures.IsEmpty) { //Execute and ExecuteAsync will return true if the operation was successful and false if not var result = transformFeatures.Execute(); //or use async flavor //await transformFeatures.ExecuteAsync(); } });
