ArcGIS.Core.Data Namespace / Selection Class / Combine Method
The second selection on which the operation will be applied.
The operation to be applied on the selections.
    Combine Method (Selection)
    Combines this selection with another selection using the specified SetOperation. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    otherSelection
    setOperation
    Return Value
    A selection satisfying the requested setOperation.
    Exceptions
    ExceptionDescription
    otherSelection is null.
    The SelectionType of this instance of selection is different from that of otherSelection.
    A geodatabase-related exception has occurred.
    Requirements
