ArcGIS.Desktop.Mapping Namespace / ParcelFabricExtensions Class / GetParcelLineLayerByTypeNameAsync Method
The parcel layer.
The parcel type name to retrieve layers.
Example
    Gets the line layer(s) for the given parcel type name.
    Syntax
    Public Shared Function GetParcelLineLayerByTypeNameAsync( _
       ByVal parcelLayer As ParcelLayer, _
       ByVal typeName As String _
    ) As Task(Of List(Of FeatureLayer))
    public static Task<List<FeatureLayer>> GetParcelLineLayerByTypeNameAsync(
       ParcelLayer parcelLayer,
       string typeName
    Parameters
    parcelLayer
    The parcel layer.
    typeName
    Return Value
    A Task to the set of line layers.
    Exceptions
    ExceptionDescription
    Insufficient license. This method requires a standard license.
    Example
    Copy standard line features into a parcel type
       string errorMessage = await QueuedTask.Run(async () =>
      // check for selected layer
      if (MapView.Active.GetSelectedLayers().Count == 0)
        return "Please select a target parcel polygon layer in the table of contents.";
      //get the feature layer that's selected in the table of contents
      var destPolygonL = MapView.Active.GetSelectedLayers().OfType<FeatureLayer>().FirstOrDefault();
      try
        var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
        //if there is no fabric in the map then bail
        if (myParcelFabricLayer == null)
          return "There is no fabric in the map.";
        var pRec = myParcelFabricLayer.GetActiveRecord();
        if (pRec == null)
          return "There is no Active Record. Please set the active record and try again.";
        string ParcelTypeName = "";
        IEnumerable<string> parcelTypeNames = await myParcelFabricLayer.GetParcelTypeNamesAsync();
        foreach (string parcelTypeNm in parcelTypeNames)
          var polygonLyrParcelTypeEnum = await myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(parcelTypeNm);
          foreach (FeatureLayer lyr in polygonLyrParcelTypeEnum)
            if (lyr == destPolygonL)
              ParcelTypeName = parcelTypeNm;
              break;
        if (String.IsNullOrEmpty(ParcelTypeName))
        var srcFeatLyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(l => l.Name.Contains("MySourceLines") && l.IsVisible);
        if (srcFeatLyr == null)
          return "Looking for a layer named 'MySourceLines' in the table of contents.";
        //now get the line layer for this parcel type
        var destLineLyrEnum = await myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(ParcelTypeName);
        if (destLineLyrEnum.Count == 0) //make sure there is one in the map
          return ParcelTypeName + " not found.";
        var destLineL = destLineLyrEnum.FirstOrDefault();
        if (destLineL == null || destPolygonL == null)
          return "";
        var editOper = new EditOperation()
          Name = "Copy Line Features To Parcel Type",
          ProgressMessage = "Copy Line Features To Parcel Type...",
          ShowModalMessageAfterFailure = true,
          SelectNewFeatures = true,
          SelectModifiedFeatures = false
        var ids = new List<long>((srcFeatLyr as FeatureLayer).GetSelection().GetObjectIDs());
        if (ids.Count == 0)
          return "No selected lines were found. Please select line features and try again.";
        editOper.CopyLineFeaturesToParcelType(srcFeatLyr, ids, destLineL, destPolygonL);
        if (!editOper.Execute())
          return editOper.ErrorMessage;
      catch (Exception ex)
        return ex.Message;
      return "";
       if (!string.IsNullOrEmpty(errorMessage))
         MessageBox.Show(errorMessage, "Copy Line Features To Parcel Type.");
    Copy parcel lines to a parcel type
         return "Please select a source parcel polygon feature layer in the table of contents.";
       try
           return "No parcel layer found in the map.";
         var srcParcelFeatLyr = MapView.Active.GetSelectedLayers().OfType<FeatureLayer>().FirstOrDefault();
         string sTargetParcelType = "Tax";
         var destLineLEnum = await myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(sTargetParcelType);
         if (destLineLEnum.Count == 0)
           return "";
         var destLineL = destLineLEnum.FirstOrDefault();
         var destPolygonLEnum = await myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(sTargetParcelType);
         if (destPolygonLEnum.Count == 0)
           return "";
         var destPolygonL = destPolygonLEnum.FirstOrDefault();
           return "";
         var theActiveRecord = myParcelFabricLayer.GetActiveRecord();
         if (theActiveRecord == null)
           Name = "Copy Lines To Parcel Type",
           ProgressMessage = "Copy Lines To Parcel Type ...",
         var ids = new List<long>(srcParcelFeatLyr.GetSelection().GetObjectIDs());
         if (ids.Count == 0)
           return "No selected parcels found. Please select parcels and try again.";
         //add the standard feature line layers source, and their feature ids to a new Dictionary
         var sourceParcelFeatures = new Dictionary<MapMember, List<long>>
           { srcParcelFeatLyr, ids }
         editOper.CopyParcelLinesToParcelType(myParcelFabricLayer, SelectionSet.FromDictionary(sourceParcelFeatures), destLineL, destPolygonL, true, false, true);
         return ex.Message;
       return "";
        MessageBox.Show(errorMessage, "Copy Parcel Lines To Parcel Type.");
    Get parcel features
      string sReportResult = "Polygon Information --" + Environment.NewLine;
      string sParcelTypeName = "tax";
          return "There is no fabric layer in the map.";
        //first get the parcel type feature layer
        var featSrcLyr = myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(sParcelTypeName).Result.FirstOrDefault();
        if (featSrcLyr.SelectionCount == 0)
          return "There is no selection on the " + sParcelTypeName + " layer.";
        sReportResult += " Parcel Type: " + sParcelTypeName + Environment.NewLine;
        sReportResult += " Poygons: " + featSrcLyr.SelectionCount + Environment.NewLine + Environment.NewLine;
        try
          // ------- get the selected parcels ---------
          var ids = new List<long>((featSrcLyr as FeatureLayer).GetSelection().GetObjectIDs());
          var sourceParcels = new Dictionary<MapMember, List<long>>
            { featSrcLyr, ids }
          ParcelFeatures parcFeatures =
                          await myParcelFabricLayer.GetParcelFeaturesAsync(SelectionSet.FromDictionary(sourceParcels));
          //since we know that we want to report on Tax lines only, and for this functionality
          // we can use any of the Tax line layer instances (if there happens to be more than one)
          // we can get the first instance as follows
          FeatureLayer myLineFeatureLyr =
              myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(sParcelTypeName).Result.FirstOrDefault();
          if (myLineFeatureLyr == null)
            return sParcelTypeName + " line layer not found";
          FeatureLayer myPointFeatureLyr =
              myParcelFabricLayer.GetPointsLayerAsync().Result.FirstOrDefault();
          if (myPointFeatureLyr == null)
            return "fabric point layer not found";
          var LineInfo = parcFeatures.Lines; //then get the line information from the parcel features object
                                             //... and then do some work for each of the lines
          int iRadiusAttributeCnt = 0;
          int iDistanceAttributeCnt = 0;
          sReportResult += "Line Information --";
          foreach (KeyValuePair<string, List<long>> kvp in LineInfo)
            if (!kvp.Key.Equals(sParcelTypeName, StringComparison.CurrentCultureIgnoreCase))
              continue; // ignore any other lines from different parcel types
            foreach (long oid in kvp.Value)
              var insp = myLineFeatureLyr.Inspect(oid);
              var dRadius = insp["RADIUS"];
              var dDistance = insp["DISTANCE"];
              if (dRadius != DBNull.Value)
                iRadiusAttributeCnt++;
              if (dDistance != DBNull.Value)
                iDistanceAttributeCnt++;
              //Polyline poly = (Polyline)insp["SHAPE"];
            sReportResult += Environment.NewLine + " Distance attributes: " + iDistanceAttributeCnt.ToString();
            sReportResult += Environment.NewLine + " Radius attributes: " + iRadiusAttributeCnt.ToString();
          var PointInfo = parcFeatures.Points; //get the point information from the parcel features object
                                               //... and then do some work for each of the points
          sReportResult += Environment.NewLine + Environment.NewLine + "Point Information --";
          int iFixedPointCnt = 0;
          int iNonFixedPointCnt = 0;
          foreach (long oid in PointInfo)
            var insp = myPointFeatureLyr.Inspect(oid);
            var isFixed = insp["ISFIXED"];
            if (isFixed == DBNull.Value || (int)isFixed == 0)
              iNonFixedPointCnt++;
            else
              iFixedPointCnt++;
            // var pt = insp["SHAPE"];
          sReportResult += Environment.NewLine + " Fixed Points: " + iFixedPointCnt.ToString();
          sReportResult += Environment.NewLine + " Non-Fixed Points: " + iNonFixedPointCnt.ToString();
          return ex.Message;
        return "";
        MessageBox.Show(errorMessage, "Get Parcel Features");
      else
        MessageBox.Show(sReportResult, "Get Parcel Features");
    Get parcel type name from feature layer
      var theparcelTypeName = await QueuedTask.Run(async () =>
        foreach (string parcelTypeName in parcelTypeNames)
          if (geomType == GeometryType.Polygon)
            var polygonLyrParcelTypeEnum = await myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(parcelTypeName);
              if (lyr == featLayer)
                return parcelTypeName;
            polygonLyrParcelTypeEnum = await myParcelFabricLayer.GetHistoricParcelPolygonLayerByTypeNameAsync(parcelTypeName);
          if (geomType == GeometryType.Polyline)
            var lineLyrParcelTypeEnum = await myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(parcelTypeName);
            foreach (FeatureLayer lyr in lineLyrParcelTypeEnum)
            lineLyrParcelTypeEnum = await myParcelFabricLayer.GetHistoricParcelLineLayerByTypeNameAsync(parcelTypeName);
        return String.Empty;
    Requirements
