ArcGIS.Desktop.Mapping Namespace / ParcelFabricExtensions Class / GetParcelTypeNamesAsync Method
The parcel layer.
Example
    Gets the parcel type names for the given parcel layer.
    Syntax
    Public Shared Function GetParcelTypeNamesAsync( _
       ByVal parcelLayer As ParcelLayer _
    ) As Task(Of List(Of String))
    public static Task<List<string>> GetParcelTypeNamesAsync(
       ParcelLayer parcelLayer
    Parameters
    parcelLayer
    The parcel layer.
    Return Value
    A Task to the set of parcel type names.
    Exceptions
    ExceptionDescription
    Insufficient license. This method requires a standard license.
    Example
    Copy standard line features into a parcel type
       string errorMessage = await QueuedTask.Run(async () =>
      // check for selected layer
      if (MapView.Active.GetSelectedLayers().Count == 0)
        return "Please select a target parcel polygon layer in the table of contents.";
      //get the feature layer that's selected in the table of contents
      var destPolygonL = MapView.Active.GetSelectedLayers().OfType<FeatureLayer>().FirstOrDefault();
      try
        var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
        //if there is no fabric in the map then bail
        if (myParcelFabricLayer == null)
          return "There is no fabric in the map.";
        var pRec = myParcelFabricLayer.GetActiveRecord();
        if (pRec == null)
          return "There is no Active Record. Please set the active record and try again.";
        string ParcelTypeName = "";
        IEnumerable<string> parcelTypeNames = await myParcelFabricLayer.GetParcelTypeNamesAsync();
        foreach (string parcelTypeNm in parcelTypeNames)
          var polygonLyrParcelTypeEnum = await myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(parcelTypeNm);
          foreach (FeatureLayer lyr in polygonLyrParcelTypeEnum)
            if (lyr == destPolygonL)
              ParcelTypeName = parcelTypeNm;
              break;
        if (String.IsNullOrEmpty(ParcelTypeName))
        var srcFeatLyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(l => l.Name.Contains("MySourceLines") && l.IsVisible);
        if (srcFeatLyr == null)
          return "Looking for a layer named 'MySourceLines' in the table of contents.";
        //now get the line layer for this parcel type
        var destLineLyrEnum = await myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(ParcelTypeName);
        if (destLineLyrEnum.Count == 0) //make sure there is one in the map
          return ParcelTypeName + " not found.";
        var destLineL = destLineLyrEnum.FirstOrDefault();
        if (destLineL == null || destPolygonL == null)
          return "";
        var editOper = new EditOperation()
          Name = "Copy Line Features To Parcel Type",
          ProgressMessage = "Copy Line Features To Parcel Type...",
          ShowModalMessageAfterFailure = true,
          SelectNewFeatures = true,
          SelectModifiedFeatures = false
        var ids = new List<long>((srcFeatLyr as FeatureLayer).GetSelection().GetObjectIDs());
        if (ids.Count == 0)
          return "No selected lines were found. Please select line features and try again.";
        editOper.CopyLineFeaturesToParcelType(srcFeatLyr, ids, destLineL, destPolygonL);
        if (!editOper.Execute())
          return editOper.ErrorMessage;
      catch (Exception ex)
        return ex.Message;
      return "";
       if (!string.IsNullOrEmpty(errorMessage))
         MessageBox.Show(errorMessage, "Copy Line Features To Parcel Type.");
    Set parcels historic
          return "Please add a parcel fabric to the map";
        try
          FeatureLayer destPolygonL = null;
          //find the first layer that is a parcel type, is non-historic, and has a selection
          bool bFound = false;
          var ParcelTypesEnum = await myParcelFabricLayer.GetParcelTypeNamesAsync();
          foreach (FeatureLayer mapFeatLyr in MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>())
            foreach (string ParcelType in ParcelTypesEnum)
              var layerEnum = await myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(ParcelType);
              foreach (FeatureLayer flyr in layerEnum)
                if (flyr == mapFeatLyr)
                  bFound = mapFeatLyr.SelectionCount > 0;
                  destPolygonL = mapFeatLyr;
                  break;
              if (bFound) break;
            if (bFound) break;
          if (!bFound)
            return "Please select parcels to set as historic.";
          var theActiveRecord = myParcelFabricLayer.GetActiveRecord();
          if (theActiveRecord == null)
          var ids = new List<long>(destPolygonL.GetSelection().GetObjectIDs());
          //can do multi layer selection but using single per code above
          var sourceFeatures = new Dictionary<MapMember, List<long>>
            { destPolygonL, ids }
            Name = "Set Parcels Historic",
            ProgressMessage = "Set Parcels Historic...",
          editOper.SetParcelHistoryRetired(myParcelFabricLayer,
            SelectionSet.FromDictionary(sourceFeatures), theActiveRecord);
          return ex.Message;
        return "";
        MessageBox.Show(errorMessage, "Set Parcels Historic.");
    Shrink parcels to seeds
        try
          FeatureLayer parcelPolygonLyr = null;
          //find the first layer that is a polygon parcel type, is non-historic, and has a selection
                  parcelPolygonLyr = mapFeatLyr;
                  break;
              if (bFound) break;
            if (bFound) break;
          if (!bFound)
            return "Please select parcels to shrink to seeds.";
            Name = "Shrink Parcels To Seeds",
            ProgressMessage = "Shrink Parcels To Seeds...",
          var ids = new List<long>(parcelPolygonLyr.GetSelection().GetObjectIDs());
          var sourceParcelFeatures = new Dictionary<MapMember, List<long>>
            { parcelPolygonLyr, ids }
          editOper.ShrinkParcelsToSeeds(myParcelFabricLayer, SelectionSet.FromDictionary(sourceParcelFeatures));
          return ex.Message;
        return "";
        MessageBox.Show(errorMessage, "Shrink Parcels To Seeds.");
    Get parcel type name from feature layer
      var theparcelTypeName = await QueuedTask.Run(async () =>
        foreach (string parcelTypeName in parcelTypeNames)
          if (geomType == GeometryType.Polygon)
            var polygonLyrParcelTypeEnum = await myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(parcelTypeName);
              if (lyr == featLayer)
                return parcelTypeName;
            polygonLyrParcelTypeEnum = await myParcelFabricLayer.GetHistoricParcelPolygonLayerByTypeNameAsync(parcelTypeName);
          if (geomType == GeometryType.Polyline)
            var lineLyrParcelTypeEnum = await myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(parcelTypeName);
            foreach (FeatureLayer lyr in lineLyrParcelTypeEnum)
            lineLyrParcelTypeEnum = await myParcelFabricLayer.GetHistoricParcelLineLayerByTypeNameAsync(parcelTypeName);
        return String.Empty;
    Requirements
