ArcGIS.Core.Data Namespace / Selection Class / GetCount Method
Example
    GetCount Method (Selection)
    Gets the count of how many items are currently contained in the selection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public long GetCount()
    Public Function GetCount() As Long
    Return Value
    The number of items currently contained in the selection.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Use Select or Search with a Spatial Query
      var mapView = MapView.Active;
      if (mapView == null)
        return;
      await QueuedTask.Run(() =>
        if (!featSceneLayer.HasAssociatedFeatureService)
          return;//no search or select
        //Select all features within the current map view
        var sz = mapView.GetViewSize();
        var map_pt1 = mapView.ClientToMap(new System.Windows.Point(0, sz.Height));
        var map_pt2 = mapView.ClientToMap(new System.Windows.Point(sz.Width, 0));
        //Convert to an envelope
        var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, mapView.Map.SpatialReference);
        //Project if needed to the layer spatial ref
        SpatialReference sr = null;
        using (var fc = featSceneLayer.GetFeatureClass())
        using (var fdef = fc.GetDefinition())
          sr = fdef.GetSpatialReference();
        var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
        //Set up a query filter
        var sf = new SpatialQueryFilter()
          FilterGeometry = env,
          SpatialRelationship = SpatialRelationship.Intersects,
          SubFields = "*"
        //Select against the feature service
        var select = featSceneLayer.Select(sf);
        if (select.GetCount() > 0)
          //enumerate over the selected features
          using (var rc = select.Search())
            while (rc.MoveNext())
              using (var feature = rc.Current as Feature)
                oid = feature.GetObjectID();
                //etc.
        mapView.Map.ClearSelection();
    Requirements
