ArcGIS.Core.Data Namespace / Selection Class / Remove Method
    Remove Method (Selection)
    Overload List
    OverloadDescription
    Removes a list of rows from the selection based on object IDs. This method must be called on the MCT. Use QueuedTask.Run.
    Removes a list of rows from the selection based on global IDs. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
