Public Property Rotation As Nullable(Of Double)
public Nullable<double> Rotation {get; set;}
//Note: Must be on QueuedTask.Run(() => { ...
//Build geometry
Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
//Reference a point symbol in a style
StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
.FirstOrDefault(item => item.Name == "ArcGIS 2D");
SymbolStyleItem symStyleItm = stylePrjItm.SearchSymbols(
StyleItemType.PointSymbol, "City Hall")[0];
CIMPointSymbol pointSym = symStyleItm.Symbol as CIMPointSymbol;
pointSym.SetSize(50);
var elemInfo = new ElementInfo()
CustomProperties = new List<CIMStringMap>() {
new CIMStringMap() { Key = "Key1", Value = "Value1"},
new CIMStringMap() { Key = "Key2", Value = "Value2"}
Anchor = Anchor.TopRightCorner,
Rotation = 45.0
var graphic = GraphicFactory.Instance.CreateSimpleGraphic(
coord2D.ToMapPoint(), pointSym);
ElementFactory.Instance.CreateGraphicElement(
layout, graphic, "New Point", true, elemInfo);
//Build geometry
Coordinate2D ll = new Coordinate2D(1.0, 4.75);
Coordinate2D ur = new Coordinate2D(3.0, 5.75);
Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
//Set symbology, create and add element to layout
CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
var ge = GraphicFactory.Instance.CreateSimpleGraphic(env, polySym);
Anchor = Anchor.CenterPoint,
Rotation = 45.0,
CornerRounding = 5.0
layout, env, polySym, "New Rectangle", false, elemInfo);
//Create a simple point text element and assign basic symbology and text settings.
//Build 2D point geometry
Coordinate2D coord2D = new Coordinate2D(3.5, 10);
CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.RedRGB, 32, "Arial", "Regular");
string textString = "Point text";
//use ElementInfo to set placement properties during create
Rotation = 45
var ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.PointText, coord2D.ToMapPoint(), sym, textString,
"New Point Text", true, elemInfo);
//Change additional text properties
ptTxtElm.SetX(4.5);
ptTxtElm.SetY(9.5);
//Build geometry
List<Coordinate2D> plCoords = new List<Coordinate2D>();
plCoords.Add(new Coordinate2D(1, 8.5));
plCoords.Add(new Coordinate2D(1.66, 9));
plCoords.Add(new Coordinate2D(2.33, 8.1));
plCoords.Add(new Coordinate2D(3, 8.5));
Polyline linePl = PolylineBuilderEx.CreatePolyline(plCoords);
var arrowInfo = new ArrowInfo()
ArrowHeadKey = ArrowInfo.DefaultArrowHeadKeys[8],
ArrowOnBothEnds = true,
ArrowSizePoints = 24,
LineWidthPoints = 12
//Create and add element to layout
GraphicElement lineElm = ElementFactory.Instance.CreateArrowGraphicElement(
layout, linePl, arrowInfo, "Arrow Line", true,
new ElementInfo() { Rotation = 15.0 });
//lineElm.SetName("New Line");
