ArcGIS.Desktop.Layouts Namespace / GraphicFactory Class / CreateLegendPatchGraphic Method / CreateLegendPatchGraphic(PatchShape,Envelope) Method
The legend patch shape
The extent of the graphic element
Example
    Create a polygon or line graphic of the specified ArcGIS.Core.CIM.PatchShape using the provided extent. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateLegendPatchGraphic( _
       ByVal patchShape As PatchShape, _
       ByVal extent As Envelope _
    ) As CIMGraphic
    public CIMGraphic CreateLegendPatchGraphic(
       PatchShape patchShape,
       Envelope extent
    Parameters
    patchShape
    extent
    Return Value
    Exceptions
    ExceptionDescription
    empty or null geometry
    Example
    Create Legend Patch Graphic
      //Note: Must be on QueuedTask.Run
      //Build geometry
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(1, 1));
      plyCoords.Add(new Coordinate2D(1.25, 2));
      plyCoords.Add(new Coordinate2D(1.5, 1.1));
      plyCoords.Add(new Coordinate2D(1.75, 2));
      plyCoords.Add(new Coordinate2D(2, 1.1));
      plyCoords.Add(new Coordinate2D(2.25, 2));
      plyCoords.Add(new Coordinate2D(2.5, 1.1));
      plyCoords.Add(new Coordinate2D(2.75, 2));
      plyCoords.Add(new Coordinate2D(3, 1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
                ColorFactory.Instance.BlackRGB, 2.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
                ColorFactory.Instance.RedRGB, SimpleFillStyle.ForwardDiagonal, outline);
      var graphic = GraphicFactory.Instance.CreateLegendPatchGraphic(
                  PatchShape.AreaBoundary, poly.Extent, polySym);
      //Make an element to add to GraphicsLayer or Layout
      //var elemInfo = new ElementInfo()
      //  CustomProperties = null,
      //  Anchor = Anchor.LeftMidPoint
      //var ge = ElementFactory.Instance.CreateGraphicElement(layout, graphic,
      //  "New Legend Patch", true, elemInfo);
    Requirements
