Return Value
ArcGIS.Core.Geometry.Envelope or null if the associated map is a scene
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
var autoCamera = mapFrame.GetAutoCamera();
autoCamera.Source = AutoCameraSource.Fixed;
autoCamera.AutoCameraType = AutoCameraType.Extent;
var mf_extent = mapFrame.GetViewExtent();
var extent = EnvelopeBuilderEx.CreateEnvelope(
400748.62, 800296.4, 1310669.05, 1424520.74, mapFrame.Map.SpatialReference);
autoCamera.Extent = extent;
if (mapFrame.ValidateAutoCamera(autoCamera) &&
!mapFrame.IsMapSeriesMapFrame())
mapFrame.SetAutoCamera(autoCamera);
