ArcGIS.Desktop.Layouts Namespace / MapFrame Class / IsMapSeriesMapFrame Method
Example
    Gets whether this map frame is associated with a layout map series. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function IsMapSeriesMapFrame() As Boolean
    public bool IsMapSeriesMapFrame()
    Return Value
    True if this is the map frame associated with a layout map series
    Exceptions
    ExceptionDescription
    Remarks
    The map series map frame name is stored in the ArcGIS.Core.CIM.CIMLayout.MapSeries, if present. Enabled status of the map series is ignored. Note: A CIMAutoCamera cannot be set on the map series map frame. Refer to SetAutoCamera.
    Example
    SetAutoCameraNone
      //Note: Must be on QueuedTask.Run
      var autoCamera = mapFrame.GetAutoCamera();
      autoCamera.Source = AutoCameraSource.None;
      if (mapFrame.ValidateAutoCamera(autoCamera) &&
        !mapFrame.IsMapSeriesMapFrame())
        mapFrame.SetAutoCamera(autoCamera);
    SetAutoCameraFixedExtent
      autoCamera.Source = AutoCameraSource.Fixed;
      autoCamera.AutoCameraType = AutoCameraType.Extent;
      var mf_extent = mapFrame.GetViewExtent();
      var extent = EnvelopeBuilderEx.CreateEnvelope(
        400748.62, 800296.4, 1310669.05, 1424520.74, mapFrame.Map.SpatialReference);
      autoCamera.Extent = extent;
    SetAutoCameraFixedCenter
      //Note: run within the QueuedTask
      autoCamera.AutoCameraType = AutoCameraType.Center;
      var camera = mapFrame.GetMapView(LayoutView.Active).Camera;
      var center = mapFrame.GetViewCenter();
      //var extent = EnvelopeBuilderEx.CreateEnvelope(
      //	400748.62, 800296.4, 1310669.05, 1424520.74, mf.Map.SpatialReference);
      //autoCamera.Extent = extent;
      var camera2 = new CIMViewCamera()
        Heading = 0,
        Pitch = -90,
        Roll = 0,
        Scale = 21169571,
        X = 855708,
        Y = 1112409,
        Z = double.NaN
      autoCamera.Camera = camera2;
      var states = mapFrame.Map.GetLayersAsFlattenedList().First(l => l.Name == "State_Polygons");
      autoCamera.IntersectLayerPath = states.URI;
    SetAutoCameraFixedScale
      autoCamera.AutoCameraType = AutoCameraType.Scale;
        Heading = 0,
        Pitch = -90,
        Roll = 0,
        Scale = 20000571,
        X = 1310669.0 + ((400748.5 - 1310669.0) / 2.0),
        Y = 800296.4 + ((1424520.74 - 800296.4) / 2.0),
        Z = double.NaN
      //autoCamera.IntersectLayerPath = states.URI;
    SetAutoCameraLinkedExtent
      autoCamera.Source = AutoCameraSource.MapFrameLink;
      autoCamera.MapFrameLinkName = "mapFrameLink";
    SetAutoCameraLinkedCenter
    SetAutoCameraLinkedCenterAndScale
      autoCamera.AutoCameraType = AutoCameraType.CenterAndScale;
    SetAutoCameraLinkedScale
    SetAutoCameraLinkedMapSeriesShape
      autoCamera.Source = AutoCameraSource.MapSeriesLink;
      //autoCamera.MapFrameLinkName = mapFrameLink;
    SetAutoCameraLinkedMapSeriesCenter
    SetAutoCameraFixedCenterAndScale
        Heading = 0,
        Pitch = -90,
        Roll = 0,
        Scale = 21169571,
        Z = double.NaN
    Requirements
