ArcGIS.Desktop.Reports Namespace / ReportElementFactory Class / CreateDynamicPictureGraphicElement Method / CreateDynamicPictureGraphicElement(IElementContainer,Envelope,String) Method
IElementContainer
Envelope
A string that represents an arcade expression defining the source.
    Creates a dynamic picture element on a report from an envelope geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateDynamicPictureGraphicElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal envelope As Envelope, _
       ByVal arcadeExpression As String _
    ) As GraphicElement
    Parameters
    elementContainer
    IElementContainer
    envelope
    Envelope
    arcadeExpression
    Return Value
    Returns a GraphicElement.
    Exceptions
    ExceptionDescription
    Invalid report section.
    Invalid report.
    Element extents outside section.
    Dynamic picture elements only valid in details section.
    Failed to create picture graphic.
    Remarks
    The element gets added to the group at the topmost position.
    Requirements
