ArcGIS.Desktop.Mapping Namespace / JPEGFormat Class / ColorMode Property
Example
    ColorMode Property (JPEGFormat)
    Gets or sets the number of bits used to describe color for JPEG.
    Syntax
    public JPEGColorMode ColorMode {get; set;}
    Public Property ColorMode As JPEGColorMode
    Remarks
    The values available are defined in JPEGColorMode.
    The default value is JPEGColorMode.TwentyFourBitTrueColor.
    Example
    Export a map frame to JPG
      //Export a map frame to JPG.
      string filePath = @"Path and file name for the output export file";
      //Create JPEG format with appropriate settings
      //BMP, EMF, EPS, GIF, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      JPEGFormat JPG = new JPEGFormat()
        HasWorldFile = true,
        Resolution = 300,
        OutputFileName = filePath,
        ColorMode = JPEGColorMode.TwentyFourBitTrueColor,
        Height = 800,
        Width = 1200
      //Export on the worker thread
      await QueuedTask.Run(() =>
        //Reference the map frame
        MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
        //Check to see if the path is valid and export
        if (JPG.ValidateOutputFilePath())
          mf.Export(JPG);  //Export the map frame to JPG
    Requirements
