ArcGIS.Desktop.Mapping Namespace / Map Class / FillFeatureCacheAsync Method / FillFeatureCacheAsync(IEnumerable<Layer>,Boolean) Method
The set of layers
Show a toast notification when the cache operation is complete.
    Fills the feature cache for the specified web feature layers (feature services) that are part of this map. Layers that are not part of this map or do not support feature caching are ignored.
    Syntax
    public Task FillFeatureCacheAsync(
       IEnumerable<Layer> layers,
       bool showNotification
    Public Overloads Function FillFeatureCacheAsync( _
       ByVal layers As IEnumerable(Of Layer), _
       ByVal showNotification As Boolean _
    ) As Task
    Parameters
    layers
    The set of layers
    showNotification
    Exceptions
    ExceptionDescription
    Filling the feature cache is only allowed on the active map.
    The fill feature cache operation cannot be executed - likely another fill cache operation is in progress.
    Remarks
    Use CanFillFeatureCache before calling this function to ensure than an existing fill feature cache operation is not already in progress.
    Requirements
