ArcGIS.Desktop.Mapping Namespace / MapTrayButton Class / IsSceneLocalMap Property
    Gets whether or not the associated MapView is a view of a 3D Local Scene.
    Syntax
    Protected ReadOnly Property IsSceneLocalMap As Boolean
    protected bool IsSceneLocalMap {get;}
    Property Value
    True if the underlying Map is a 3D Local Scene, false otherwise.
    Remarks
    Only ever true if this TrayButton has been added to a MapView's Tray.
    This may initially be false, as the view is being constructed. Override the TrayButton.OnButtonLoaded method to be told when the view is made available.
    Requirements
