Parameters
- uri
- A System.Uri represents the path or url to a dataset or .lyrx or .lpkx file.
// Create a new stretch colorizer definition using default constructor.
StretchColorizerDefinition stretchColorizerDef = new StretchColorizerDefinition();
// Create a raster layer creation parameters object with the raster file path.
var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri("rasterPath"))
ColorizerDefinition = stretchColorizerDef,
Name = "rasterLayerName",
MapMemberIndex = 0
// Create a raster layer using the colorizer definition created above.
// Note: You can create a raster layer from a url, project item, or data connection.
//Note: Run within a QueuedTask
RasterLayer rasterLayerfromURL =
LayerFactory.Instance.CreateLayer<RasterLayer>(rasterLayerCreationParams, map);
// Create a new colorizer definition using default constructor. { StretchColorizerDefinition stretchColorizerDef = new StretchColorizerDefinition(); var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri("url")) { Name = "layerRasterName", ColorizerDefinition = stretchColorizerDef, MapMemberIndex = 0 }; // Create a mosaic layer using the colorizer definition created above. // Note: You can create a mosaic layer from a url, project item, or data connection. //Note: Run within a QueuedTask MosaicLayer newMosaicLayer = LayerFactory.Instance.CreateLayer<MosaicLayer>(rasterLayerCreationParams, map); }
var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri(url))
Name = "RasterLayer",
MapMemberIndex = 0
// Create an image service layer using the colorizer definition created above.
ImageServiceLayer imageServiceLayerWithColorizer =
LayerFactory.Instance.CreateLayer<ImageServiceLayer>(rasterLayerCreationParams, map);
