ArcGIS.Desktop.Mapping Namespace / IElement Interface / SetCustomProperty Method / SetCustomProperty(String[],String[]) Method
String
String
    Sets multiple CustomProperty values for the element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Sub SetCustomProperty( _
       ByVal keys() As String, _
       ByVal values() As String _
    void SetCustomProperty(
       string[] keys,
       string[] values
    Parameters
    keys
    String
    values
    String
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    This method was created so developers have a way to uniquely assign a value or multiple values to an element that can not be changed in the UI and therefore provides a predictable way to find an element. Each entry has a key/value pair and you find the value using the GetCustomProperty method. You can overwrite values simply be reentering the same key with a different value. There are no methods to remove keys.
    Requirements
