ArcGIS.Desktop.Mapping Namespace / IElement Interface / SetTOCPositionAbsolute Method
Reference to a Layout or a GroupElement
Boolean
    SetTOCPositionAbsolute Method (IElement)
    Sets the position of an element either at the top or bottom of the layout TOC or a group element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Sub SetTOCPositionAbsolute( _
       ByVal targetContainer As IElementContainer, _
       ByVal isTop As Boolean _
    void SetTOCPositionAbsolute(
       IElementContainer targetContainer,
       bool isTop
    Parameters
    targetContainer
    isTop
    Boolean
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    If set to true, the element is placed at the top of the layout TOC or the top position in a group element. Elements can be easily moved into or out of groups.
    Requirements
