ArcGIS.Desktop.Mapping Namespace / IElement Interface / SetY Method
Double
    SetY Method (IElement)
    Sets the Y position of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Sub SetY( _
       ByVal y As Double _
    void SetY(
       double y
    Parameters
    y
    Double
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    This element requires its mapview to be active
    Remarks
    Placement for an element contained in graphics layer requires the mapview be active. To change the element X and Y consider SetAnchorPoint
    Requirements
