public void CreateSlice( SliceDefinition sliceDef )
Public Sub CreateSlice( _ ByVal sliceDef As SliceDefinition _ )
Parameters
- sliceDef
- The definition of the slice to be created
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
| System.ArgumentException | Invalid slice definition specified |
| System.ArgumentNullException | Null slice specified |
await QueuedTask.Run(() =>
if (voxelLayer.Visualization != VoxelVisualization.Volume)
voxelLayer.SetVisualization(VoxelVisualization.Volume);
voxelLayer.SetSliceContainerExpanded(true);
voxelLayer.SetSliceContainerVisibility(true);
//To stop the Voxel Exploration Dockpane activating use:
voxelLayer.AutoShowExploreDockPane = false;
//This is useful if u have your own dockpane currently activated...
//Use the SelectedVariableProfile to get the slices currently in the TOC
//via its associated volume
var volume = voxelLayer.SelectedVariableProfile.Volume;
var volumeSize = volume.GetVolumeSize();
//Orientation 90 degrees (West), Tilt 0.0 (vertical)
//Convert to a normal
var normal = voxelLayer.GetNormal(90, 0.0);
//Create the slice at the voxel mid-point. VoxelPosition
//is specified in voxel-space coordinates
//Create the slice on the respective volume
volume.CreateSlice(new SliceDefinition()
Name = "Middle Slice",
VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2),
Normal = normal,
IsVisible = true
//reset if needed...
voxelLayer.AutoShowExploreDockPane = true;
