ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVolume Class / UpdateSlice Method
The definition of the slice to be updated
Example
    UpdateSlice Method
    Updates the slice identified by the input SliceDefinition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void UpdateSlice(
       SliceDefinition sliceDef
    Public Sub UpdateSlice( _
       ByVal sliceDef As SliceDefinition _
    Parameters
    sliceDef
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Invalid slice definition specified
    Slice not found in the collection of slices
    Slice definition is null
    Example
    Get the Collection of Slices
      await QueuedTask.Run(() =>
        //Use the SelectedVariableProfile to get the slices currently in the TOC
        //via its associated volume
        var volume = voxelLayer.SelectedVariableProfile.Volume;
        var slices = volume.GetSlices();
        //Do something... e.g. make them visible
        foreach (var slice in slices)
          slice.IsVisible = true;
          volume.UpdateSlice(slice);
        //expand the slice container and make sure container visibility is true
        voxelLayer.SetSliceContainerExpanded(true);
        voxelLayer.SetSliceContainerVisibility(true);
    Change Tilt on a Slice
        //To stop the Voxel Exploration Dockpane activating use:
        voxelLayer.AutoShowExploreDockPane = false;
        //This is useful if u have your own dockpane currently activated...
        //Normally, it would be set in your dockpane
        if (voxelLayer.Visualization != VoxelVisualization.Volume)
          voxelLayer.SetVisualization(VoxelVisualization.Volume);
        var slice = volume.GetSlices().First(s => s.Name == "Change Tilt Slice");
        (double orientation, double tilt) = voxelLayer.GetOrientationAndTilt(slice.Normal);
        //Convert orientation and tilt to a normal
        slice.Normal = voxelLayer.GetNormal(orientation, 45.0);
        //reset if needed...Normally this might be when your dockpane
        //was de-activated (ie "closed")
        voxelLayer.AutoShowExploreDockPane = true;
    Requirements
