ArcGIS.Desktop.TaskAssistant Namespace / TaskAssistantFactory Class / Instance Property
Example
    Instance Property (TaskAssistantFactory)
    Gets the singleton instance for TaskAssistantFactory
    Syntax
    public static TaskAssistantFactory Instance {get;}
    Public Shared ReadOnly Property Instance As TaskAssistantFactory
    Example
    Open a Task File - .esriTasks file
    // Open a task file
    try
      // TODO - substitute your own .esriTasks file to be opened
      string taskFile = @"c:\Tasks\Get Started.esriTasks";
      //At 2.x -
      //System.Guid guid = await TaskAssistantModule.OpenTaskAsync(taskFile);
      System.Guid guid;
      if (TaskAssistantFactory.Instance.CanOpenTaskFile(taskFile))
        guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile);
      // TODO - retain the guid returned for use with CloseTaskItemAsync
    catch (OpenTaskException e)
      // exception thrown if task file doesn't exist or has incorrect format
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(e.Message);
    Open a Project Task Item
      // get the first project task item
      var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault();
      // if there isn't a project task item, return
      if (taskItem == null)
        return;
      try
        // Open it
        //At 2.x -
        //System.Guid guid = await TaskAssistantModule.OpenTaskItemAsync(taskItem.TaskItemGuid);
        var guid = await TaskAssistantFactory.Instance.OpenTaskItemAsync(taskItem.TaskItemGuid);
    Close a Task Item
      // find the first project task item which is open
      var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault(t => t.IsOpen == true);
        return;
      if (taskItem.IsOpen)
        // close it
        // NOTE : The task item will also be removed from the project
        //At 2.x -
        //TaskAssistantModule.CloseTaskAsync(taskItem.TaskItemGuid);
        TaskAssistantFactory.Instance?.CloseTaskItemAsync(taskItem.TaskItemGuid);
    Export a Task Item
        return;
      try
        // export the task item to the c:\Temp folder
        string exportFolder = @"c:\temp";
        //At 2.x -
        //string fileName = await TaskAssistantModule.ExportTaskAsync(taskItem.TaskItemGuid, exportFolder);
        string fileName = await TaskAssistantFactory.Instance.ExportTaskItemAsync(taskItem.TaskItemGuid, exportFolder);
        ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Task saved to " + fileName);
      catch (ExportTaskException e)
        ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Error saving task " + e.Message);
    Get Task Information - from an .esriTasks file
      string message = await QueuedTask.Run(async () =>
        string msg = "";
        try
          // retrieve the task item information
          //At 2.x -
          //TaskItemInfo taskItemInfo = await TaskAssistantModule.GetTaskItemInfoAsync(taskFile);
          TaskItemInfo taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
          msg = "Name : " + taskItemInfo.Name;
          msg += "\r\n" + "Description : " + taskItemInfo.Description;
          msg += "\r\n" + "Guid : " + taskItemInfo.Guid.ToString("B");
          msg += "\r\n" + "Task Count : " + taskItemInfo.GetTasks().Count();
          msg = e.Message;
        catch (TaskFileVersionException e)
          // exception thrown if task file does not support returning task information
          msg = e.Message;
        return msg;
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(message, "Task Information");
    Open a specific Task in a Task File - .esriTasks file
        try
          //At 2.x -
          var taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
          // find the first task
          TaskInfo taskInfo = taskItemInfo.GetTasks().FirstOrDefault();
          Guid guid = Guid.Empty;
          if (taskInfo != null)
            // if a task exists, open it
            //At 2.x -
            //guid = await TaskAssistantModule.OpenTaskAsync(taskFile, taskInfo.Guid);
            guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile, taskInfo.Guid);
          else
            // else just open the task item
            //At 2.x -
            //guid = await TaskAssistantModule.OpenTaskAsync(taskFile);
    Requirements
